Catalyst 9200 license for prime infrastructure
Hi there,
trying to create BOM (Bill of materials) for one project which includes Catalyst 9200 as access layer switch. However, there is no C1 license for 9200, I want to add license under prime infrastructure, but cant find it.
Is there license for 9200 catalyst for PI?
thanks in advance,
HTH,
6 Replies 6
UP
HTH,
any luck?
ciscoazlancco
Up. I have the same question ...
Only C93XX, C94xx and C95xx can be found within R-MGMT3X-N-K9
We had phone call with local Cisco company and they said that, for now, you can use management-tokens (L-MGMT3X-TKN-K9= ) for Catalyst 9200. Per token per C9200.
Details about tokens can be found here: https://www.cisco.com/c/dam/en/us/products/collateral/cloud-systems-management/prime-infrastructure/presentation-c97-735996.pdf
HTH,
Thank you Kanan.
I just found a 92xx SKU:
L-MGMT3X-92XX-K9=
