Catalyst C3560CX, Unable to attach flow monitor to vlan
Nirivana
I was trying to configure bridged NetFlow on 3560CX.
I followed the configuration guide:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960cx_3650cx/software/release/15-2_7_e/configuration_guide/b_1527e_consolidated_3560cx_2960cx_cg/m_1522e_fnf_fnf_2960x_cg.html#task_A53900A8C0F743EFB85D77C4D666E091
I got an error when attempting to apply Flow Monitor to the VLAN:
3560CX(config-vlan-config)#ip flow monitor STD_NF_MON_1 input
% Flow Monitor: 'STD_NF_MON_1' could not be added.
Below is my configuration:
flow record STD_NF9_1
 description * STANDARD NF RECORD *
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 collect counter bytes long
 collect counter packets long
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
flow exporter STD_NF_EXP_1
 destination 10.x.x.x
 source Vlan1
 transport udp 9055
 template data timeout 60
 record STD_NF9_1
Any help here is appreciated... Thanks..
balaji.bandi
are you applying any range of VLAN ?
show us before this commmand, post complete config you doing right form config t to this error to undertand the issue.
BB
Pls see below:
3560CX#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
3560CX(config)#vlan configuration 1
3560CX(config-vlan-config)#ip flow mon STD_NF_MON_1 input
Configuring a Bridged NetFlow on a VLAN
You can apply a flow monitor and an optional sampler to a VLAN.
SUMMARY STEPS
  1. configure terminal
  2. vlan [configuration ] vlan-id
  3. interface {vlan } vlan-id
  4. ip flow monitor monitor name [sampler sampler name] {input |output }
  5. copy running-config startup-config
# configure terminal
(config)# vlan configuration 1
(config)# interface vlan 1
3560CX(config-vlan-config)ip flow mon STD_NF_MON_1 input
BB
I am aware. I tried copying the exact configuration for bridge NetFlow from the guide and the result is the same. I am not sure if this is due to the limitations of CX switches or some of the parameters in the flow record is not supported.
The reason why I am not applying to SVI is that I have VLANS that do not have SVI configured.
I have tried Bridge NetFlow on Catalyst 9300 switches and did not encounter any errors...
