CDP neighbors / VTP doesn't work because of firewall?
eeebbunee
--- Delete this post because I re-created post this related issue.
8 Replies 8
CDP and VTP use multicast to MAC address 01:00:0c:cc:cc:cc, they are link layer (2) protocols. Can you check if the pfSense blocks that MAC address ?
This FW run in routed or transport mode?
are you making any progress on this ? Can you turn off/on CDP globally, enable debugging, and post the output of 'debug cdp adjacency' ?
Also, does the pfSense firewall log show any entries ?
--deleted
post the output of:
show vtp status
from both the core 3750X and the L2 switch.
--deleted
Notes:-
*The transparent mode ASA does not pass CDP packets packets, or any packets that do not have a valid EtherType greater than or equal to 0x600.
**the traffic pass from high to low permit , traffic from low to high deny.
I appreciate your respond, but I am using PFSense firewall not ASA firewall.
How Cisco protocol works on other devices are connected in the middle?
