Changing device credentials on Prime Infrastructure
kerim mohammed
Level 3
Level 3
I just imported device list from LMS4.2 to prme infrastructure. Now, i would like to change the device credential for all devices on prime infrastructure all at once. the only way i got it working was one device at a time. is there a way to do bulk edit on device credentials on prime infrastructure 1.2?
Kerim
a.perrichon
I have the same problem. Did you find any solutions ?
Thanks.
I haven't yet found anything. was busy with other activity. cisco realease quick deployment guide in Jan.2013, you might want to take a look at that.
I asked to a Cisco pre sales, and he confirmed that the feature is not yet available
cwallin
One way would be to edit the LMS export before importing. Just open the csv and do a replace on the credentials.
