Changing Login Module to MS Active Directory in LMS 3.2
dionjiles
Hi all,
I'm attempting to change the login module to MS Active Directory, but it appears that I don't have something configured properly.
I'm following the steps from the Common Services user guide http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.3/user/guide/CommonServicesUserGuide.pdf
For the userroot session I have the following: cn=users, dc=corp, dc=citistreet, dc=org
AD-Domain: corp.citistreet.org
The name of the server I am using is a PDC server we use.
Any suggestions on what is misconfigured?
dionjiles
Sorry...I had it misconfigured.
But it's still not working though.
Server name.
LDAP://HWPDC500.corp.citistreet.org/dc=corp,DC=citistreet,DC=org
Useroot:
ou=Accounts, ou=Jacksonville, dc=corp, dc=citistreet, dc=org
RDN-Prefix: cn=
Is there anything else that needs to be configured?
The only way I could get AD lookups working for LMS was to enable anonymous ldap operations within 2003. Not ideal but it works.
http://www.petri.co.il/anonymous_ldap_operations_in_windows_2003_ad.htm
n.kaced01
Did you solved your problem ?
