DHCP CONFLICT *
¿Hay un comando o configuración que hará un router automáticamente clear conflicto ip dhcp * sobre una base regular? Tengo un sitio que constantemente tiene un problema con DHCP debido a los conflictos que se fija simplemente borrando la tabla de conflictos. Si pudiéramos automatizar esto ??
Aztec_
Hi Alexander,
Rather than clear conflict table automatically, we should prevent conflict.
First of all, you must trace the conflict IP and find the root cause.
If the conflict IP is used by network device, configure DHCP exclude to exclude those ip so it wouldn't distributed by DHCP.
If the conflict IP is between user, try to make sure all user devices use DHCP and not static IP.
