Cisco 1010 ports not coming back on after reboot
taitas
I'm new to this so please be kind
Setting up a Cisco 1010 Firepower device, unboxed it, got it up and running, havent' did any config yet, so its all the defaults I would say.  Needed to bring it to the office, once I turn it on, no port lights come on, and I've left it on for a day.
I have all 3 green lights on the top, with the middle one flashing.
need some help please
10 Replies 10
check the duplex and Speed in Device connect to FPR
MHM
taitas
wow thanks for the quick reply !   How would I check that?  I can only get to the console with Rommon 1 prompt?
MHM
taitas
Thanks @Aref Alsouqi  I've re-imaged it, doing the same thing.  no lights on the 8 ports.  If I go to putty and type boot, it will boot and lights come on, then I do a reboot, lights off.  I'm missing something somewhere
You're welcome. It could be related to a wrong config-register value. From rommon try please to type the "confreg 0x1" and see if that fixes the issue.
If that command does not work, please try to issue the command "confreg" and hit enter, and hopefully that will fix it.
taitas
thank you !!!  that did it, back online now
You're welcome. Out of interest, which one of the suggested solutions work? the "confreg 0x1" or "confreg" followed by hitting enter? please mark the correct answer to benefit the other readers.
confreg 0x1 worked for me
