Cisco 1700 Series T1 Point to Point Change Clock Source
broomstar
So I am trying to change the clock source on my already setup cisco t1 point to point, but it wont allow me to. I have had many people tell me 10 different things that I have to do but no one seems to know how. I put in the command clock source internal, but it says its an invalid command. Any help would be much appreciated.
5 Replies 5
Karim.elwardany
have you tried IOS upgrade?
No I havent because I dont know which one to upgrade to nor do I know how really.
My current version is....
IOS (tm) C1700 Software (C1700-SV3Y-M), Version 12.2(8)YN, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc1)
Synched to technology version 12.2(11.2u)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 30-Oct-02 10:22 by ealyon
Image text-base: 0x80008120, data-base: 0x80F47D4C
ROM: System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-SV3Y-M), Version 12.2(8)YN, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
pe-wen-01 uptime is 1 day, 18 hours, 19 minutes
System returned to ROM by reload
System restarted at 10:02:41 PDT Tue Jun 12 2012
System image file is "flash:c1700-sv3y-mz.122-8.YN.bin"
cisco 1751 (MPC860P) processor (revision 0x600) with 36864K/12288K bytes of memo
ry.
Processor board ID JAD06370AF0 (4055773928), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
2 Channelized T1/PRI port(s)
WIC T1-DSU
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
I appreciate the posted link however I cant see the bugtoolkit unfortunately. So if your saying its a bug within my IOS then I need to upgrade. Are there any easy steps to follow on how to do this, or any easy way to know what version to upgrade to?
