Cisco 1841 and 2811 + AIM-VPN/SSL
bednarczykm
Hello everyone,
I have i my network HP NNM 7.51 for monitoring. The problem is monitoring the AIM-VPN/SSL CPU utilization. I have it on cisco 1841 and 2811. NNM use SNMP for monitoring. Which MIB and which value should I check for this task?
Best regards,
Michal B.
Richard Burts
Michal
I am not aware of CPU to monitor in the AIM-VPN/SSL.
Rick
Rick
Thank you Rick,
I was looking for some MIBs for this module but I didn't find anything.
Maybe you're right. But this is strange for me, I can monitor a few MIB objects and why I can't this module?
Best regards,
Michal
