CISCO 2620xm Router IOS Help Please..
SCORPION69
Hello..I purchased a Cisco 2620XM Router with a FastEthernet NM-1FE-TX module in it, from a Business Auction that was held in my area.
- The current IOS is c2600-ipbase-mz.122-5
- How do I obtain the latest IOS for the router?? (Base Image with Firewall)....or whatever someone would like to suggest.
I would like to configure and use the router on my home network... it would be the (A) Roadrunner Cable Modem__>>>__(B) Cisco 2620xm Router__>>>__(C) Microsoft ISA 2006 Server......but I would remove the ISA server if the router has the Firewall in it.
I tried to find the IOS versin that is the latest and greatest.
Any suggestions are welcomed.....
Thanks......
David Stanford
It looks like someone has already replied to your duplicate post under Lan switching and routing.
If you don't have access to download the IOS from cisco.com then you'll need to go through your account rep or reseller to get access to IOS images.
