cisco 2911 ios 15.2(4)M3 netflow problem for interface tunnel gre
kaabiayman1
Hi support,
i configured netflow version 9 for a remote cisco 2911 for interface g0/1 and interface tunnel gre.
In our netflow analyzer we receive the interface g0/1 but not the interface tunnel gre .
can you explain me the problem.
please see the version output and the netflow configuration:
RT-0162701#sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 26-Feb-13 03:42 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
RT-0162701 uptime is 2 weeks, 6 days, 7 hours, 41 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 909312K/40960K bytes of memory.
Processor board ID FCZ172660ZE
3 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FCZ172660ZE
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
ip flow-export source Loopback0
ip flow-export version 9
ip flow-export destination 172.31.32.40 9996
interface GigabitEthernet0/1
description Link to RT-9160103
ip address 10.202.16.27 255.255.0.0
ip access-group Allow-GRE in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip ospf message-digest-key 1 md5 ****************
duplex auto
speed auto
no cdp enable
no mop enabled
interface Tunnel1627
description Link to RT-9160103- $BLR(SLC)$
ip address 10.208.16.105 255.255.255.252
ip flow ingress
ip flow egress
no ip route-cache cef
ip ospf cost 200
keepalive 10 3
tunnel source 10.202.16.27
tunnel destination 10.202.51.1
tunnel checksum
Bharat Chandani
It looks like CEF is not working for tunnel's traffic. Netflows are constructed only for CEF switched traffic.
We have "no ip route-cache cef" configured on inteface. Please remove this and check.
Could you please refer to the below mentioned logs:-
Show ip cef 10.202.51.1
show flow monitor test-flow cache
sh ip cache flow
thanks for your reply,
i removed the ip route-cache cef but no change . i don't receive this interface.
please see these outputs
RT-0162701#sh ip cef 10.202.51.1
10.202.51.1/32
attached to GigabitEthernet0/1
RT-0162701#
RT-0162701#
RT-0162701#
RT-0162701#sh flow monitor NFAINrecord cache
Cache type: Normal
Cache size: 4096
Current entries: 2
High Watermark: 5
Flows added: 3843
Flows aged: 3841
- Active timeout ( 60 secs) 3121
- Inactive timeout ( 15 secs) 720
- Event aged 0
- Watermark aged 0
- Emergency aged 0
IPV4 SOURCE ADDRESS: 10.202.51.1
IPV4 DESTINATION ADDRESS: 10.202.16.27
TRNS SOURCE PORT: 0
TRNS DESTINATION PORT: 0
INTERFACE INPUT: Gi0/1
IP VERSION: 4
IP TOS: 0xC0
IP PROTOCOL: 47
interface output: Null
counter bytes long: 1908
counter packets long: 20
timestamp abs first: 12:29:12.730
timestamp abs last: 12:29:59.110
TRNS SOURCE PORT: 0
IP VERSION: 4
IP TOS: 0x00
IP PROTOCOL: 47
counter bytes long: 50263
counter packets long: 401
timestamp abs first: 12:29:45.770
timestamp abs last: 12:30:00.446
RT-0162701#
RT-0162701#
RT-0162701#
RT-0162701#sh ip cache flow
IP packet size distribution (2208587 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.019 .019 .318 .218 .091 .023 .014 .008 .038 .008 .002 .010 .002 .001 .001
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.001 .004 .001 .015 .198 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
2 active, 4094 inactive, 16736 added
962692 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 34056 bytes
0 active, 1024 inactive, 9569 added, 9569 added to flow
0 alloc failures, 0 force free
1 chunk, 0 chunks added
last clearing of statistics 5d02h
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
UDP-DNS 11 0.0 1 65 0.0 1.0 15.6
GRE 16725 0.0 132 378 5.0 54.4 2.7
Total: 16736 0.0 131 378 5.0 54.3 2.7
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Gi0/1 10.202.51.1 Local 10.202.16.27 2F 0000 0000 19
Gi0/1 10.202.51.1 Local 10.202.16.27 2F 0000 0000 446
RT-0162701#
RT-0162701#
any update guys i need support to solve this problem.
