Cisco 2921/K9 CPU Temperature Thresholds
Hello! Our CPU temperature appears to be running a little high, although the device is reporting it as Normal. For monitoring purposes, I am wondering what we should use as Warning and Failed, so we can make sure everything is running well. Thank you!
SYSTEM POWER SUPPLY STATUS
Internal Power Supply Type: AC
Internal Power Supply 12V Output Status: Normal
External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
Fan 1 OK, Medium speed setting
Fan 2 OK, Medium speed setting
Fan 3 OK, Medium speed setting
Fan 4 OK, Medium speed setting
SYSTEM TEMPERATURE STATUS
Intake Left temperature: 34 Celsius, Normal
Intake Right temperature: 33 Celsius, Normal
Exhaust Left temperature: 38 Celsius, Normal
Exhaust Right temperature: 38 Celsius, Normal
CPU temperature: 54 Celsius, Normal
Power Supply Unit temperature: 46 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
SYSTEM POWER
Motherboard Components Power consumption = 70.2 W
Total System Power consumption is: 70.2 W
Environmental information last updated 00:00:16 ago
Mark Malone
here is the data sheet with the recommended temp parameters , looks fine to me above , its when it hits 80 or higher your going to have issues
http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
Mark Malone
Hi All,
I have problem on one of the 2911 device which is showing intake left temperature showing minus value.
Any one help me on this . Why this is showing minus value.
Intake Left(Bezel) temperature: 30 Celsius, Normal
Intake Left temperature: -22 Celsius, Normal
Exhaust Right(Bezel) temperature: 35 Celsius, Normal
Exhaust Right temperature: 34 Celsius, Normal
CPU temperature: 72 Celsius, Normal
Power Supply Unit temperature: 32 Celsius, Normal
