04-11-2017 03:49 AM
hello everyone, i'am facing a problem ....my cisco catalyst switch 2960 is booting again & again .and showing an error
error : asic/phy post failed an not continue...
what can i do...
Solved! Go to Solution.
04-11-2017 03:53 AM
Power-on self test (POST) failures are hardware-related.
You need to open a TAC case. Cisco TAC will issue a Return Material Authorization (RMA) and send you a new switch.
If you don't have Cisco Smartnet contract support then you will need to replace the switch.
04-11-2017 03:53 AM
04-11-2017 04:37 AM
Ok thank you sir ..
04-11-2017 04:56 AM
You're welcome.
Please mark your question as answered if it has been.
10-09-2023 07:35 AM - edited 10-09-2023 07:36 AM
Hello Marvin, You mean the following error "POST: PortASIC Port Loopback Tests : Begin
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 9
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 15
POST: PortASIC Port Loopback Port Tests : End, Status Failed
Error: ASIC/PHY POST failed. Cannot continue" implies only RMA change?
11-24-2021 10:52 PM
asic/phy post failed. cannot continue
11-25-2021 11:38 PM
what happens after ? Does the switch boot up ? Check if you hit the bug below:
2960X crash during boot up with Error: ASIC/PHY POST failed
CSCut90593
Description
Symptom:
Conditions:
POST: PortASIC Port Loopback Tests : End, Status Failed
Error: ASIC/PHY POST failed. Cannot continue.
%Software-forced reload
Workaround:
the switch can boot up normally after this crash
Known Affected Releases (1)
15.0(2)EX
Known Fixed Releases (7)
3.7(2)E
3.6(3)E
15.2(6.3.0i)E
15.2(5.0)ST
15.2(4.0.64a)E
15.2(3)E2
15.2(2)E3
