%WEBSERVER-5-CONNECTION_FAILED: Switch 1 R0/0: nginx: connection faile
nevermore266
%WEBSERVER-5-CONNECTION_FAILED: Switch 1 R0/0: nginx: connection failed from host 172.12.24.1 - Cipher Mismatch/No shared ciphe with cisco switch
Mark Elsen
              - To which platform (and or model) are you trying to connect ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hellow Guys
You need to delete the certificate "no crypto pki trustpoint TP-self-signed"
and delete all configs about ip http and ip http secure
then config again the ip http and ip http secure and a new certificate signed will be created
the issue is presented when the certificate is old and the explorer is using new certificates
good luck!!
