cisco 2960-x express setup does not submit ip settings
BG147
After applying new ip settings in express setup, I press submit but the changes do not apply.
A new page opens to the new ip but after setting nic to the same subnet I cannot connect.
I change back to dhcp and connect to the default 10.0.0.1 again.
i have tried multiple browsers and computers.
Mark Elsen
 - Is there an error when you press Submit ? You may be able to initially configure through the console, check this thread :
         https://community.spiceworks.com/topic/1243946-cisco-2960g-24tc-l-no-express-setup-after-resetting
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
5 Replies 5
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Hello, No no error...
 - Ok , as stated check out the  thread.
       Beauty and terror
      Just keep going
       No feeling is final
Thank you! ive been at it for a few hours! This worked
Do you know how to reset the switch from CLI? Pressing the mode button does not do a factory reset as manual states. I cannot log into one switch because the default password doesn’t work.
