cisco 3650 ldap via radius ssh mode enable
johnblack2045
Hello All
i m using cisco 3650 and ldap via radius (freeradius) solution to authentificate on my switch
when i use an ldap account and its password i can access on to my switch in user mode
that s works
when i want to use mode ena i can 't use its password but only the password enable in my configuration switch
question
i use aaa authentication login default group radius local .....
how should i configure my switch to allow password of ldap account ?
i don't want any ldap account automatically access on  my switch with privilege mode because security
is there any solution (switch configuration , freeradius ?).
Thanks for your answer
Best Regards
LDAP and RADIUS are two different protocols, I assume you are referring to RADIUS in this case? If you are using RADIUS with Freeradius, I think you would need to configure the enable password on the RADIUS server, since when you type enable command on the network device, a RADIUS authentication request will be sent to the RADIUS server looking for the configured enable15 password. If that is not set or if it different, it will fail.
