Cisco 3750x configuration
Sureshkachwa
Got new AT&T connection and ISP cable will be directly plugged into switch port gig 1/0/1
I will not have any sort of physical connection to the switch all I need to do is share the configuration and ask someone to copy and paste it and should be able to take SSH over switch public ip.
Will the below configuration work?
#enable
#conf t
#hostname
#ip domain-name
#crypto key generate
#ip routing
#ip default gateway <ISP_next_hop>
#int gig 1/0/1
#no shutdown
#ip address <isp_public_ip> <subnet_mask>
#exit
#line vty 0 15
#username xxxxx password xxxxxx
#transport input SSH
#login local
#exit
#wr mem
There is no vpn concept involved,all we need is to connect to the switch public ip over SSH and clients, Meraki APs will also be connected to the same switch.
ISP has DHCP and DNS enabled,I hope.
Please guide,Thanks!!
5 Replies 5
Sureshkachwa
I am thinking to leave all the interfaces part of vlan1, create a vlan interface 1, assign an IP for management ?
No firewall in place since we don't need it.
Seb Rupik
Hi there,
I would suggest you also add an ACL the the vty lines to prevent SSH access from all but public IPs that you control:
access-list 10 permit <public_ip_of_hq> 0.0.0.0
access-list 10 deny any
line vty 0 15
  access-class 10 in
cheers,
Seb.
@Seb Rupik , is the above config good?
I think we will have only one public IP from ISP.
Hi there,
Assuming you are not running a LAN base license you will be able to configure gi1/0/1 as a routed port as you have in your config. If not, then you will need to configure a SVI. You should include the access-class config to provide some additional security to your device.
You will also need to configure a DHCP scope for your wireless clients on VLAN 1.
As your wireless clients will be using private IPs you will need to NAT that subnet to use the gi1/0/1 IP as the global outside address.
The 3750x does not support NAT, so you will need to use a router or firewall to provide that function.
cheers,
Seb.
Sureshkachwa
@Seb Rupik  , sure, can you please help me out with the entire configuration, I mean if my configuration is correct or not for SSH access over the internet to a switch public ip and clients,Meraki APs will also be connected to same switch
