04-07-2015 11:52 PM
Dear All,
I have 5 cisco 3750X switches ,but only 4 switches coming up 5 switches i am unable to see .
Connection for the switch :Please find the attached snapshot for the stack data connection .
Also find the snapshot for the stack power connection .
Please provide your assistance and support to overcome this issue .
04-08-2015 02:34 AM
Data from stack_data_connection.jpg & stack_power_connection.jpg are useless.
show_switch_snapshot.jpg is showing the stack were all powered up simultaneously. Have you tried checking the power for switch stack #5?
04-08-2015 03:46 PM
The 3750-X models have a data stack and power stack. The power stack is limited to four switches, so a fifth one would have to be in a separate power stack.
You can form a data stack however with up to 9 members. When you plug into console on switch #5, what does it show for "show switch detail".
04-08-2015 10:59 PM
Dear Marvin,
Thanks for your reply.
is my connection provided in attachment for data stack are ok .
i login to Switch # 5 through console
following is the result :--
switch: ?
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
memory -- Present memory heap utilization information
mgmt_clr -- clear management port statistics
mgmt_init -- initialize management port
mgmt_show -- show management port statistics
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
ping -- Send ICMP ECHO_REQUEST packets to a network host
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
sleep -- Pause (sleep) for a specified number of seconds
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
switch: version
C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE, RELEASE SOFTWARE (fc1)
Compiled Tue 26-Apr-11 06:59 by abhakat
switch: boot
Loading "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"...flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin: no such file or directory
Error loading "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch:
All other 4 switches i can see in stack but not these switches and also the status light for this switches is blinking green please provide your assistance .
04-09-2015 07:54 AM
Your switch is not booting IOS and is is the pre-boot condition known as "rommon". (Read Only Memory MONitor)
This is usually due to a deleted or corrupted IOS image. You need to recover the image and boot the IOS fully for the switch to be able to join the data stack. Here is a reference to the commands available to you in rommon mode.
Use dir to figure out what you have and then copy to move the files into flash (if necessary). Then boot using the restored image.
04-10-2015 01:15 AM
Dear Marvin ,
can you please provide me the link to download c3750e-universalk9-mz.122-58.SE2.bin
04-10-2015 05:49 AM
You will need a support contract associated with your cisco.com userid to be eligible to download the image.
