cisco 4500 failed to upgrade ISO
Dr.X
Level 2
Level 2
Im not able to upgrade the IOS to at4500e-entservicesk9-mz.152-4.E10.bin - it always revert back to IP-BASE old ISO
4500E#sh run | i boot
boot-start-marker
boot system flash bootflash:cat4500e-entservicesk9-mz.152-4.E10.bin
boot-end-marker
4500E#dir bootflash:
Directory of bootflash:/
6 -rw- 38791882 Jan 27 2019 11:12:52 +00:00 cat4500e-ipbasek9-mz.152-2.E8.bin
7 -rw- 41609690 Feb 25 2023 04:34:12 +00:00 cat4500e-entservicesk9-mz.152-4.E10.bin
8 -rw- 35 Mar 23 2019 03:17:50 +00:00 pnp-tech-time
9 -rw- 1523 Mar 23 2019 03:17:52 +00:00 pnp-tech-discovery-summary
128282624 bytes total (37240832 bytes free)
4500E#sh bootvar
BOOT variable = bootflash:cat4500e-entservicesk9-mz.152-4.E10.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x2101
4500E#sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 15.2(2)E8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 22-Jan-18 06:32 by prod_rel_team
ROM: 12.2(44r)SG9
4500E uptime is 3 hours, 42 minutes
System returned to ROM by reload
System image file is "bootflash:cat4500e-ipbasek9-mz.152-2.E8.bin"
Hobgoblin Revision 20, Fortooine Revision 1.40
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4948E (MPC8548) processor (revision 5) with 1048576K bytes of memory.
Processor board ID CAT1524S1KJ
MPC8548 CPU at 1GHz, Cisco Catalyst 4948E
Last reset from Reload
6 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
And below is console reboot :
*Mar 10 01:17:10.277: %SYS-5-RELOAD: Reload requested by m0uln4500 on vty0 (176.        58.70.9). Reload Reason: Reload command.
 * Welcome to Rom Monitor for     WS-C4948E System        *
 * Copyright (c) 2003-2010 by Cisco Systems, Inc.         *
 * All rights reserved.                                   *
Checking the partition table and boot sector...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
 Rom Monitor Program Version 12.2(44r)SG9
 CPU Rev: 2.1, Board Rev: 5, Board Type: 104, CPLD Hobgoblin Rev: 20
 Chassis: WS-C4948E
Front Panel Phy is Bcm5482s
Got Mac Address: 00:07:7d:64:05:3f
 MAC Address  : 00-07-7d-64-05-3f
 Ip Address   : Not set.
 Netmask      : Not set.
 Gateway      : Not set.
 TftpServer   : Not set.
 Peer supervisor not detected or is not running IOS
 Supervisor uplinks and all linecards have been reset
 ***** The system will autoboot in 5 seconds *****
 Type control-C to prevent autobooting.
 ******** The system will autoboot now ********
 config-register = 0x2101
 Autobooting using the first file from bootflash.....
Rommon reg: 0x00004780
Reset2Reg: 0x00009EFF
Fortooine controller 0x0B5C7394..0x0B72F90B original size:0x001C685D
diagsk5 version 5.0.2.3
prod: WS-C4948E part: 73-13472-01 serial: CAT1524S1KJ
Power-on-self-test for Module 1: WS-C4948E
CPU Subsystem Tests ...
 seeprom: Pass
Traffic: L3 Looopback ...
 Test Results: Pass
Traffic: L2 Loopback ...
 Test Results: Pass
Switching Subsystem Memory ...
 Packet Memory Test Results: Pass
Module 1 Passed
Rommon reg: 0x00000780
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, Catalyst 4500 L3 Switch  Software (cat4500e-IPBASEK9-M), Ver        sion 15.2(2)E8, RELEASE SOFTWARE (fc1)
export@cisco.com.
1 Virtual Ethernet interface
Press RETURN to get started!
*Mar 10 01:20:31.543: %C4K_SWITCHINGENGINEMAN-6-BFDINVALIDPACKETACLAPPLIED: Cont        rol plane protection against invalid BFD packets is applied
*Mar 10 01:20:51.567: %SMI-5-CLIENT:  Smart Install Client feature is enabled. I        t is recommended to disable the Smart Install feature when it is not actively us        ed. To disable feature execute 'no vstack' in configuration mode
*Mar 10 01:20:51.635: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for typ        e vlan
*Mar 10 01:20:56.051: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4948E S/N        : CAT1524S1KJ Hw: 2.0) is online
*Mar 10 01:20:59.591: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 10 01:20:59.887: %SYS-5-RESTART: System restarted --
*Mar 10 01:21:00.063: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Abort        ed by non-PnP bootstrapping)
*Mar 10 01:21:00.083: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar 10 01:21:02.995: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=49: Transc        eiver has been inserted
*Mar 10 01:21:06.991: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=50: Transc        eiver has been inserted
*Mar 10 01:21:08.015: %EC-5-BUNDLE: Interface GigabitEthernet1/42 joined port-ch        annel Port-channel45
*Mar 10 01:21:08.035: %EC-5-BUNDLE: Interface GigabitEthernet1/43 joined port-ch        annel Port-channel45
*Mar 10 01:21:08.039: %EC-5-BUNDLE: Interface GigabitEthernet1/44 joined port-ch        annel Port-channel45
*Mar 10 01:21:08.047: %EC-5-BUNDLE: Interface GigabitEthernet1/45 joined port-ch        annel Port-channel45
*Mar 10 01:21:08.051: %EC-5-BUNDLE: Interface GigabitEthernet1/47 joined port-ch        annel Port-channel45
*Mar 10 01:21:08.067: %EC-5-BUNDLE: Interface GigabitEthernet1/48 joined port-ch        annel Port-channel45
*Mar 10 01:21:08.991: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=51: Transc        eiver has been inserted
*Mar 10 01:21:09.991: %EC-5-BUNDLE: Interface GigabitEthernet1/46 joined port-ch        annel Port-channel45
*Mar 10 01:21:11.991: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=52: Transc        eiver has been inserted
*Mar 10 01:21:16.047: %EC-5-BUNDLE: Interface Te1/51 joined port-channel Po10
*Mar 10 01:21:17.195: %EC-5-BUNDLE: Interface Te1/49 joined port-channel Po10
 Use a different config-register.
Switch(config)# config-register 0x2102
