Cisco 4500X lost its cpu snmp oid
as00001111
Hey all!
I was monitoring the cpu utilization with that oid: 1.3.6.1.4.1.9.9.109.1.1.1.1.4.1000
A few days ago, we had a power loss, the cisco switch was powered off.
As of that, I can't get the cpu utilization anymore. The oid doesn't exist anymore.
What can I do?
Thank you!
6 Replies 6
marce1000
 - Try walking the OID partially ; perhaps it got slightly changed.
M.
How exactly?
 - Something like :
           snmpwalk -v 1 -c community  switchname  1.3.6.1.4.1.9.9.109.1.1.1.1.4
M.
it says:
iso.3.6.1.4.1.9.9.109.1.1.1.1.4 = No Such Object available on this agent at this OID
 - Try shorting the OID start-string even more when testing with snmpwalk  use e.g:  1.3.6.1.4
M.
I did that and I get a lot of results.
What am I supposed to do now?
The problem is:
I did snmpwalk -v 2c -c string hostname  1.3.6.1.4.1.9.9
and the results are:
1.3.6.1.4.1.9.9.106.xxxx and then
1.3.6.1.4.1.9.9.117.xxxx
"109" is completely missing.
