Cisco 800 series -> Cisco Cat. 2960 Switch (connection)
GiuCO
Hy! I have a Cisco 800 to which I want to connect a Cisco 2960 switch, the problem is that when I connect the switch to one of the f0-3 ports I don't have a link, if I connect any other device (PC) to the f0-3 ports I also have a link and internet .
If I restart the router and the switch simultaneously, they communicate with each other until a certain moment.
Where am I wrong?
GiuCoRouter#
Using 1920 out of 262136 bytes
! Last configuration change at 19:41:43 UTC Sat Jun 27 2020
! NVRAM config last updated at 19:50:16 UTC Sat Jun 27 2020
version 15.1
no service pad
hostname GiuCoRouter
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.150.9 192.168.150.14
ip dhcp pool NAT
 network 192.168.150.0 255.255.255.0
 default-router 192.168.150.9
 dns-server 8.8.8.8 8.8.4.4
 domain-name GiuCO
 lease 7
ip cef
no ipv6 cef
license udi pid C881G+7-K9 sn FCZ164490U4
spanning-tree portfast bpduguard
controller Cellular 0
interface FastEthernet0
 switchport access vlan 9
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address 10.0.0.9 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Cellular0
 no ip address
 encapsulation slip
interface Vlan1
 no ip address
interface Vlan9
 ip address 192.168.150.9 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 10.0.0.138
access-list 100 permit ip 192.168.150.0 0.0.0.31 any
control-plane
line con 0
 logging synchronous
line aux 0
line 3
 no exec
line vty 0 4
 login
 transport input all
End
GiuCoSwitch1#
 Using 1954 out of 65536 bytes
version 15.0
no service pad
service password-encryption
hostname GiuCoSwitch1
boot-start-marker
boot-end-marker
enable secret 5 $1$zTvJ$OyLgDIf4ZZyr8dl1KapXP.
enable password 7 11584C504644585F
no aaa new-model
system mtu routing 1500
crypto pki trustpoint TP-self-signed-2442885376
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2442885376
 revocation-check none
 rsakeypair TP-self-signed-2442885376
crypto pki certificate chain TP-self-signed-2442885376
 certificate self-signed 01 nvram:IOS-Self-Sig#2.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 ip address 192.168.150.1 255.255.255.0
ip default-gateway 192.168.150.9
ip http server
banner motd ^C
Cisco Catalyst 2960 Switch Powered & Used by Giu C.O.
Unauthoriyed access is Prohibited
^C
line con 0
 password 7 0257510E5A505C72
 login
line vty 0 4
 login
line vty 5 15
 login
end
luis_cordova
Hi @GiuCO
Try leaving the port of device 800, which connects to the switch, in trunk mode.
Currently, the ports of device 800 are in access mode, so they may be being blocked by STP.
Remember to assign 2960 ports to vlan 9.
