cisco 881 with flash error
zhangvif
Hello folks, I installed the Cisco Configuration Professional Express 3.5.3 into a cisco 881-k9 flash successfully, but after an updating the ios by using this new CCPE interface, the update page has turned to endlessly waiting, after 10-15min, I had to power off the unit to interrupt the operation, but since then the unit can't boot and it says can't boot from flash.
under the rommon mode, I tried to tftpdnld the ios, but no success, it fails after transferring the file to router saying can't access flash, but I can still dir flash:, but I can't dir bootflash:, so I presume after tftp ios to router it still needs to read or write from flash in order to execute the firmware, for this reason, I used tftpdnld -r, but same result, it fails every time finishing transfer the ios file to router.
my question is can we boot the unit with a usb key instead, then format flash afterward? or the unit is really bricked? the systems says "can't read flash fs", I guess it's the flash file is messed up. any suggestion? thank you!
balaji.bandi
if you have USB, copy the stable image to USB and try to boot let us know if that works ?
>boot usbflash0:stable-image.bin (replace stable-image.bin with your working IOS name).
if it boots success.
post below commands output :
show version
show boot
dir
BB
H Balaji, I tried to format a 2G usb key since I don't have any smaller size, I used fdisk to resize it down to 256M and even 128M to let router recognize it, but failed again, the system always says can't load, I don't know what's the reason.
Also the strange thing is as I've mentioned in my 1st post, why tftpdnld -r fails? the ios was successfully transferred to router, but it fails right after than, so I guess it must needs a tmp folder to decompress the files and that default temp folder would be flash: then, I'm wondering if there is a way to set the default device from flash: to usbflash0: instead? Under the rommon mode, we don't have much option.
I'm also thing of Jtag option, but I have limited info for that alternative, any other suggestion? Thank you!
format the USB with FAT 32 format.
BB
