Cisco AAA RADIUS - What Authentication Protocol Does It Use?
Mike Mertens
Community Member
We use RADIUS for authenticating network admins logging into routers/switches. We use a Windows Server 2019 running NPS as our RADIUS server, which is apparently using NTLMv1 on the back end to authenticate to LDAP/AD. We need to move off of NTLMv1 (per Windows admin) but I am not familiar with the NPS configuration. Anyway, diving deeper into RADIUS, and I found and think I understand that the RADIUS server (or client?) can use NLTMv1, PAP, CHAP, MS-CHAP, EAP, EAP-TLS for authorization. So then, I should be able to reconfigure the NPS for RADIUS with something other than NTLM. However, that got me wondering: What does a Cisco router/switch configured for using RADIUS under AAA use to pass the user/password to the RADIUS server? What is the default config method, and how can I modify this? So when I SSH to a switch, the switch prompts me for userid/password, which is encrypted in SSH, but how do I see the encryption method for the switch-to-RADIUS server communication?
It seems the more I read, the more I'm getting confused.
Thanks for any clarification anyone can bring.
Mike
2 Accepted Solutions
SW/R--radius--NPS (server)--NTLM--LDAP server
So between SW/R and NPS there is only radius protocol.
MHM
The Authentication protocol from the RADIUS client (the switch/router) to the RADIUS server (your NPS) is PAP/ASCII. What happens between the NPS and the Directory-server depends heavily on the environment.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
M02@rt37
Hello @Mike Mertens
Which RADIUS authentication method do you expect to use ?
Best regards
I guess "anything but NTLMv1", as that is what the Windows team is trying to retire. I'm quite confused right now as it seems that between the Windows NPS and AD/LDAP it is RADIUS with NTLMv1(?) and then I wonder: does that mean that RADIUS is using NTLMv1 between router/switch and the NSP RADIUS server? Or are these RADIUS "Access-Request", "Access-Accept", "Access-Reject" messages are application-layer on top of UDP being used between Cisco router/switch to the NPS/RADIUS server, then NPS is using NTLMv1between it and AD/LDAP?
THANKS!
Mike
MHM
