08-12-2013 04:49 AM
i have a Cisco ACS but i found out that i got a error..
| Managed Device Count Exceeded |
what can i do to fix this problem. i dont't have many devices around 30 and my max is 500, i got ip range's to identify the devices so should i manualy add all the devices?
what can also happen if i leave this error like it is...?
thanks
Solved! Go to Solution.
08-14-2013 07:50 AM
Hi Johan,
We ran into this problem as well - you can't use wildcards or large ranges that would cause you to exceed the 500 device limit (like you could in ACS 3.2). To get around this I setup the default network device setting and then in the Access Policies setup a default catch all at the end. The rules above the default are typically ones that require tighter access restrictions. Hope that helps.
Brian
08-14-2013 07:50 AM
Hi Johan,
Brian
08-19-2013 02:04 AM
thanks that helpt allot.
but can this be harmfull if you leave it like as is ?
or will something stop working ??
