Cisco ACS Managed Device Count Exceeded
i have a Cisco ACS but i found out that i got a error..
what can i do to fix this problem. i dont't have many devices around 30 and my max is 500, i got ip range's to identify the devices so should i manualy add all the devices?
what can also happen if i leave this error like it is...?
thanks
Brian Saunders
Hi Johan,
We ran into this problem as well - you can't use wildcards or large ranges that would cause you to exceed the 500 device limit (like you could in ACS 3.2).  To get around this I setup the default network device setting and then in the Access Policies setup a default catch all at the end.  The rules above the default are typically ones that require tighter access restrictions.  Hope that helps.
Brian
Brian Saunders
Hi Johan,
Brian
thanks that helpt allot.
but can this be harmfull if you leave it like as is ?
or will something stop working ??
