Cisco ap disassociated from controller on PRIME
huseyin
Hi everyone
We installed a lot of Cisco Switches, 2 wireless controllers, and a lot of APs.
Also, we installed Cisco PRIME. The Cisco Prime version is 3.9.0.0.219. Also, I added Security Update and Device Pack files. All switch platforms work on PRIME successfully. But all APs are not. When I click Controllers or APs I see a blank webpage. I added a lot of screenshots. As you can see; ALL APs disassociated from the controller. Do you know how I can fix it?
Regards.
6 Replies 6
@huseyin
 Try to remove the WLC from cisco prime and add it again. As long as the WLC is not successfully communicating with Cisco Prime, what you are seing is actually the expected behavior.
huseyin
Unfortunately, this solution was a growing problem. For this reason, we found a bug! I couldn't delete this WLC.  Also, I couldn't add this WLC again. I need a different solution.
Cisco Bug: CSCvx50660 Unable to delete wireless LAN controllers from Prime Infrastructure
You need TAC assistance. They are able to get to the Prime data base and manuallly remove the entry.
huseyin
I was working on my Lab. And I successfully deleted Controller from PRIME.
But When I try to add again. It can not happen.
On C9800 WLC CLI portal;
C9800-CL#
Oct 3 10:38:14.053: %SSH-3-NO_MATCH: No matching mac found: client hmac-sha1-96,hmac-sha1,hmac-md5-96,hmac-md5,hmac-sha2-256,hmac-sha2-512 server hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com
Oct 3 10:38:14.053: %SSH-5-SSH2_SESSION: SSH2 Session request from 192.168.40.26 (tty = 1) using crypto cipher '', hmac '' Failed
Oct 3 10:38:14.054: %SSH-5-SSH2_CLOSE: SSH2 Session from 192.168.40.26 (tty = 1) for user '' using crypto cipher '', hmac '' closed
What is that? Do You have any Idea?
huseyin
On C9800 CLI Screen;
C9800-CL#sh ip ssh
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:ssh-rsa,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519,x509v3-ecdsa-sha2-nistp256,x509v3-ecdsa-sha2-nistp384,x509v3-ecdsa-sha2-nistp521,rsa-sha2-256,rsa-sha2-512,x509v3-rsa2048-sha256
Hostkey Algorithms:rsa-sha2-512,rsa-sha2-256,ssh-rsa
Encryption Algorithms:chacha20-poly1305@openssh.com,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-gcm,aes256-gcm,aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com
KEX Algorithms:curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group14-sha256,diffie-hellman-group16-sha512
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): CLOUDM_PKEY
Modulus Size : 2048 bits
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCrtQ111wlzeTAnlhYY+y2RXvdMHdmvPYdMrWH/oWxl
1EhXBdJqtklu+Zkn6caEXSYJeU/h3fgdCBKWR0vtvTOseo956/NM41aRu05sfIbJKcEt1ZkSnIecYpie
/+xq+An9P2hGai1LwSF4PHiUjjjF+hit3UXuNhOd5Hf27HfG0mboK2e3Gc8ePD5dgUISN8byBwjFI+Mv
w5Jk+8bjCkpqj4/KwN/BWgQjXWXKlrmFb6H2z87sM9OMG/Yz9Jn0krNqKE44IC2xvGk9+NXHZafDH8qx
tAJynTsmEJSWPQmwl7jac2Fsg5fkmug2BYdDfcAxXjLBSYFfOpi06sVoWTD7
On Prime CLI Screen;
prime/admin# sho security-status
Open TCP Ports : 21 22 443 1522 8078 8080 8082 8087 9992 20830 61617
Open UDP Ports : 69 162 514 9991
FIPS Mode : disabled
SSH Legacy
Algorithms : enabled
TFTP Service : enabled
JMS port(61617) : enabled
Root Access : enabled
Certificate validation settings for pubnet
Cert check : enabled
OCSP check : disabled
Auto CA update : enabled
Certificate validation settings for system
Cert check : trust-on-first-use
Auto CA update : disabled
Certificate validation settings for devicemgmt
Certificate validation settings for user
Algorithm settings enabled for SSH service
KexAlgorithms : diffie-hellman-group16-sha512,diffie-hellman-group14-sha256,ecdh-sha2-nistp52
1,ecdh-sha2-nistp384,ecdh-sha2-nistp256,curve25519-sha256@libssh.org,diffie-hellman-group18-sha
512,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha256,diffie-hellman-group-excha
nge-sha1,diffie-hellman-group1-sha1
MACs : hmac-sha2-512,hmac-sha2-256,hmac-sha1
Ciphers : aes128-gcm@openssh.com,aes128-ctr,chacha20-poly1305@openssh.com,aes256-ctr,ae
s256-gcm@openssh.com,aes192-ctr,3des-cbc,aes128-cbc,aes256-cbc
TLS versions : TLSv1.2
TLS ciphers : tls-ecdhe-sha2,tls-static-sha2
Note : Shows currently configured values
Changes made after last system start if any,
will be effective after next restart
prime/admin#
