ā07-28-2022 01:34 AM
I am trying to install Cisco APIC v 5.2(e) o a VMware virtual machine. The installation starts and after a few secons stops and vm turns off.
I am using aci-apic-dk9.5.2.2e.iso and have given 4 cpus and 16GB of RAM to the vm. What do you think the problem is?
ā07-28-2022 12:15 PM
hard to say. The iso image is quite large, what machine or you installing this on, and what VMware version ?
ā07-30-2022 01:17 AM
I am using aci-apic-dk9.5.2.2e.iso image. I have VMWare Workstation 16.2.
I resolved to ova file but again VMWare didn't import it but virtualbox had no problem importing the file. I have not turned on the machine yet, though.
ā07-30-2022 01:21 PM
4 processors and 16GB RAM sounds like it should be enough. What is the maximum of RAM you can assign ? The file size is >6GB, how much disk space do you have left ?
ā07-30-2022 11:28 PM
I have 64GB of RAM on my server and 32 should be allocated to other VMs. Disk space is ample.
I read somewhere that I need at least 1 physical APIC to have vAPICs in my network. This might be reason since I am trying to install the APIC on a virtual machine. I had luck with VAPIC but in the end it did not initialize, maybe because of that reason.
ā07-31-2022 01:00 AM
can you actually run the APIC in VirtualBox ? I don't know if I am looking at the correct page, but in the compatibility matrix linked below, neither Workstation nor Virtual Box are listed at all...
ā07-31-2022 01:17 AM
That's a great reference! Thanks for the link.
I actually tried installing on virtualbox with the same result! I guess, I might try on ESX, though I have installed Windows on my server as the main OS.
ā08-01-2022 12:15 AM
I cannot really test this on my own machine, since I do not have the ISO image you are using. Maybe it is possible for you to post it on a download site ? Probably not completely legal, but if I have the image, I can run some tests here as well.
According to that matrix, it should not run on Workstation or VirtualBox at all...
ā08-01-2022 10:45 PM
I coud get it deon this torrent:
magnet:?xt=urn:btih:1A16AACE95C0C84F513BF8F6EB2822A74E8FD476&dn=Nexus3K_9K
ā08-02-2022 12:49 AM - edited ā08-02-2022 12:52 AM
I am trying to get the torrent, it might take a while...
EDIT: I noticed the size of the torrent is 461GB, that does not look right. Did you actually download this one ?
ā08-02-2022 08:40 AM
No, of course not.
The torrent contains a number of files and you need to download only the mentioned file and skip others.
