Cisco ASA 5585 interface traffic collection
deepfree1
Hello gents,
I have a Cisco ASA model 5585 and i have the IBM Qradar at company i work. The question is do i have any way to check the exist connection that goes through the ASA via the outside interface so i can understand who (which host IP) is overloading the network ?
What exactly do i need to do to make IBM Qradar and Cisco ASA friends ? At Qradar threre is a tree made for outside interface how can i send traffic from ASA to Qradar to be shown ? Or may be there is another way i can see what i need.
Regards.
Seb Rupik
HI there,
I’ve never used QRadar, but a quick look at the documents shows showing call QFlow Collector. You will need to configure that to accept netflow data originating from the ASA destined to a particular UDP port on the QRadar instance.
On the ASA you will then need to configure netflow, in particular the export destination:
https://www.cisco.com/c/en/us/td/docs/security/asa/special/netflow/guide/asa_netflow.html#pgfId-1330480
Once the collector starts receiving the data it should be simple enough to filter on outbound flows with high bps values or high data volumes.
cheers,
Seb.
