02-25-2015 11:05 AM
I have observed a billion messages like the following, on syslog :
Feb 23 10:12:32 wlan-controller-14-2 impa-wireless2: *spamReceiveTask: Feb 23 10:12:29.570: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 24 18:18:44 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 24 18:18:44.064: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Cisco Adaptive Security Appliance Software Version 9.0(4)
Device Manager Version 7.3(1)101
ASA# sh int gigabitEthernet 0/2
Interface GigabitEthernet0/2 "", is up, line protocol is up
Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
Input flow control is unsupported, output flow control is off
Description: Smale-Ethernet10/3
Active member of Port-channel32
MAC address 5475.d091.4f04, MTU not set
IP address unassigned
575994720 packets input, 230167959667 bytes, 0 no buffer
Received 31034901 broadcasts, 0 runts, 0 giants
54 input errors, 0 CRC, 0 frame, 54 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
671225576 packets output, 541877862255 bytes, 0 underruns
0 pause output, 0 resume output
0 late collisions, 0 deferred
0 input reset drops, 0 output reset drops, 0 tx hangs
input queue (blocks free curr/low): hardware (511/486)
output queue (blocks free curr/low): hardware (511/355)
(Cisco Controller) >show inventory
Burned-in MAC Address............................ 00:1E:13:50:AA:80
Maximum number of APs supported.................. 6
NAME: "Chassis" , DESCR: "2100 Series WLAN Controller:6 APs"
PID: AIR-WLC2106-K9, VID: V03, SN: JMX1151K0DY
AIR-WLC2106-K9 controller is ruunning Software Version 7.0.251.2
(Cisco Controller) >debug capwap detail enable
*spamReceiveTask: Feb 23 10:12:36.756: 54:75:d0:91:4f:04 LWAPP Primary Discovery Request AP Software Version: 0x700fa00
(Cisco Controller) >debug arp all enable
*dtlArpTask: Feb 24 18:18:42.242: processEtherIcmp: Received ICMP request from wired client,Interface no:1, mtu:1280, SRC MAC: 54:75:D0:91:4F:04
*dtlArpTask: Feb 24 18:18:42.242: dtlArpFind: ARP Lookup succeeded on IP 147.65.14.7
*dtlArpTask: Feb 24 18:18:42.242: processEtherIcmp: Sending ICMP reply Successful !! , SRC MAC: 00:1E:13:50:AA:80
(Cisco Controller) >show arp kernel
IP address HW type Flags HW address Mask Device
147.65.14.7 0x1 0x2 54:75:D0:91:4F:04 * dtl0
(Cisco Controller) >show arp switch
Number of arp entries................................ 142
MAC Address IP Address Port VLAN Type
54:75:D0:91:4F:04 147.65.14.7 1 14 Host
00:23:04:49:9E:40 147.65.14.239 1 14 Permanent
00:21:A0:FE:A7:C0 147.65.14.240 1 14 Permanent
F8:66:F2:63:0F:00 147.65.14.241 1 14 Permanent
Controller management interface GW address : 147.65.14.7
Other controllers : 147.65.14.239, 147.65.14.240 and 147.65.14.241
ASA interface g 0/2 mac address : 54:75:D0:91:4F:04
Any idea?
02-25-2015 11:55 AM
Are any of your APs going thru the firewall to get to the WLAN controller?
02-25-2015 11:59 AM
Yes
02-25-2015 02:46 PM
A couple of more questions:
1. Are you using DHCP and, if yes, do you have option 43 defined in your DHCP?
See this link for more information:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-00.html
2. Do you have LWAPP(5246/5247) and CAPWAP (12222/12223) ports open on the firewall?
02-26-2015 11:26 AM
Yes I am using option 43 as described on DHCP OPTION 43 for Lightweight Cisco Aironet Access Points Configuration Example.
There are no firewall droped ports --> LWAPP(5246/5247) and CAPWAP (12222/12223) .
Everityng runs fine, except those billion messages sent to syslog which I suppose are sent by pix asa to syslog and are also seen by (Cisco Controller) >debug arp all enable:
02-26-2015 03:21 PM
The messages indicate the controller is dropping the LWAPP requests because it knows the AP can do CAPWAP. I am not sure if what you are seeing is a bug, but for some reason the CAPWAP messages are not arriving.
Everything is, however, working because you have dhcp option 43 with the controllers IP address.
Have you tried adding ip forward protocol udp 12222 and ip forward-protocol udp 12223 on your L3 device where you point the AP's DHCP requests to the DHCP server? Where you have your ip helper-address statement.
I will dig in more.
02-26-2015 03:34 PM
Correction. I meant:
ip forward protocol udp 5246
ip forward-protocol udp 5247
02-27-2015 04:06 AM
I supose you do not understand.
The billion messages come from PIX ASA.
Rosa
02-27-2015 10:51 AM
In answer to my first question you said the APs are going thru the firewall to reach the Controller. Correct?
That means on L2 the Controller sees ALL L2 traffic coming from the firewall. Therefore, you see the ASA's Mac address. You will not see the AP's MAC address. I though that was clear.
This message:
" *spamReceiveTask: Feb 25 17:00:09.198: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP"
means the controller knows the AP can do CAPWAP, but it is receiving LWAPP, and is, therefore, discarding it.
What version of s/w are you running on the Controller(s)?
02-27-2015 10:57 AM
Correct.
Yes I see ASA's macaddress.
7.0.251.2 for software and emergency.
There is somthing importante to tell you.
management and ap_manager are in different vlans.
I am concened that is the problema.
I am just working to have one of the four controllers configured with ap-manager and management in the same vlan.
02-27-2015 03:32 PM
Yes, it is recommended that they both be in the same VLAN.
I would also consider having the "management" interface act as AP Manager (this can beset via the Dynamic AP Management check box). I don't know how many ports you are using, but specs indicate one AP-Management interface per port.
We use DHCP Option 43, and we have a DNS entry for
cisco-capwap-controller.domain_name pointing to Management interface of the controller. If you have a different AP-Management interface, then DNS entry should point to the AP-Management IP for CAPWAP.
02-27-2015 07:05 PM
That is exactly what a I did for one of the four controllers I have, and as expected all messages for this controller disappear.
If everythig runs fine this weekend I will extend the solution for the other 3 controllers.
Thanks for your help.
Rosa
02-28-2015 09:21 AM
Excellent!
Best wishes.
02-25-2015 12:03 PM
I have 26 APs.
Take a look the ping's frequence ( 8 times per second):
Feb 25 16:57:38 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:57:31.496: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:57:51 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:57:44.397: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:57:59 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:57:52.681: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:09 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:02.414: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:16 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:09.242: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:20 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:13.341: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP[...It occurred 3 times/sec!.]
Feb 25 16:58:31 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:24.049: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:36 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:29.198: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:37 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:30.526: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:41 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:34.223: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:47 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:40.782: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:49 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:41.830: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:50 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:42.920: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:51 wlan-controller-14-1 impa-wireless1: *apfReceiveTask: Feb 25 16:58:44.514: %LOG-6-Q_IND: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:58:54 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:58:47.177: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:59:10 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:59:03.155: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:59:14 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:59:07.301: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:59:18 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:59:11.018: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:59:34 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:59:27.279: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:59:36 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:59:29.413: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP[...It occurred 2 times/sec!.]
Feb 25 16:59:38 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:59:31.449: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:59:51 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:59:44.384: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 16:59:59 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 16:59:52.667: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:08 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:01.657: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:16 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:09.198: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:17 wlan-controller-14-1 impa-wireless1: *mmListen: Feb 25 17:00:10.153: %LOG-6-Q_IND: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP[...It occurred 2 times.!]
Feb 25 17:00:20 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:13.328: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:30 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:23.007: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:35 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:28.441: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:37 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:30.515: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:41 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:34.179: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:47 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:40.737: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:49 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:42.163: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP[...It occurred 2 times/sec!.]
Feb 25 17:00:50 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:43.303: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
Feb 25 17:00:54 wlan-controller-14-1 impa-wireless1: *spamReceiveTask: Feb 25 17:00:47.163: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1835 Discarding Primary discovery request in LWAPP from AP 54:75:d0:91:4f:04 supporting CAPWAP
