Cisco ASDM Compatability with ASA 9.9(2)
NeWGuy1109
we have a Cisco Firepower 2120 in our environment with ASA IOS 9.9(2).
In the following link it shows that 9.9(2) is compatible with ASDM 7.9(2)+ , what does the + sign mean ? if i have ASDM 7.9(2.152) will it support 9.9(2) ? Does '+' means that every extension of 7.9(2.x) will work with this OS or particularly 7.9(2) is required.
https://www.cisco.com/c/en/us/td/docs/security/asa/compatibility/asamatrx.html
Seb Rupik
Hi there,
Your summary is correct. The plus symbol can be interpreted as saying the specified ASDM version and above is compatible with that ASA-OS release.
So 7.9(2.152) > 7.9(2) and is therefore supported.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
