cisco ASR1002-HX
quboseho
After the back massage I moved to the back of her legs. Starting with her feet I gently massaged the soles and toes before moving up to her calf and then to the upper part of her leg. With long slow strokes my hands slid up the centre of her leg to just below her knicker line. One hand swept down the outside and the other hand down the inside of her leg. This was one of my favourites and with hot glistening oil it was more of a sensual technique. I continued this way for a while with my hands reaching higher and higher up her thigh to the point I was feeling the cheek of her bum. Again I asked if she was ok and she said yes. When I changed position to concentrate on her other leg I noticed her shifting slightly and parting her legs by a few inches. Was she uncomfortable or was it something else?!
https://titsgifs.com
I repeated my long slow sensual strokes on the back of her other leg but this time I took even longer as I was loving the feel of her skin and the little soft moans I thought I could hear when I ran my hand down the inside of her thigh. Wow. This was turning me on. This was my aunts friend. I wanted to touch her more.
I eventually finished massaging the back of her legs and asked her to turn over. Ever the gent I helped her turn over with a discreet towel in place to cover her breasts. Pushing the bottom towel up over her knickers to apply more oil I was met with the most wonderful sight. As the knickers were white and cotton it showed an apparent damp patch that had appeared. She was obviously unaware of what secrets the knickers told me. She was wet. I was flattered and very turned on.
I spent little time on the lower half of her leg before moving to her thigh. This time though I was slower than ever and made sure that when my hand reached the top of her thigh and began the downward travel down the inside of her leg I rested my fingers near to her knicker line. I was about an inch away from her **bleep**. On the odd occasion my finger gently slipped inside her knicker line and felt her hair. Not too much as I didn't want a slap but I was confused as she didn't say no. Should I? Shouldn't I? I was really pushing my luck. I needed to stay professional and, this was a friend of my aunt. I decided not to try anything....just in case.
As it was turning me on so much I massaged her thighs and inside of her legs longer than I normally would I could see her squirming slightly and also saw her mouth open and close when I was close to her **bleep**. Her knickers became more and more wet. This was such an erotic experience. Never in a million years did I see myself being so turned on by massaging the older body of a friend of my aunt. I decided to bring the massage to a close as I was desperate to get home and replay the massage again in my head while playing with my **bleep**.
Covering her with a hot towel I also covered her eyes and told her to relax. She dozed off - had she orgasmed? Did she enjoy it? Did she want more. I decided to leave her relaxing so let myself out but left her a short note saying 'hope that helps'. As soon I was home I came within minutes. What an experience. What turn-on. My aunt called me a few days later to say that Isabelle had the most wonderful time and could I return soon. "Of course" I said wondering how far would I go next time?
balaji.bandi
interface g0/0/4
snmp trap link-status
This is the default state of the config, if you like to look that config issue show run all
try to shut and no shut ( check the trap,) is your Trap server Listening ? to config this generatingor not, enable syslog so you can see on the Console.
In case required user guide of ISR :
Global command - snmp-server trap link switchover
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/snmp/command/nm-snmp-cr-book/nm-snmp-cr-s5.html#wp1417114193
BB
