Hello all,
Need some help, if possible.
Want to perform a pilot for MACSEC over WAN and was thinking to use ASR1k.
I have found this document saying that ASR1k require this license FLSA1-MACSEC1G to run MACSEC.
https://www.cisco.com/c/en/us/products/collateral/application-networking-services/wide-area-application-services-waas-software/data-sheet-c78-729778.html
But what I cannot find is what other requirements are there; do I need IP base, advanced IP services, advanced enterprise services license or MACSEC license is enough.
Do not plan to run any other testing, just MACSEC over WAN (over a layer 2 circuit, ASR1K ports should be configured as access).
I have tried raising license support case which sent me to call +1 800-553-6387 option 1, then 2 which asked all sorts of questions none related to my inquiry. Is it that hard to get the details you need before ordering anything from Cisco?
Thank you,
