Cisco Business Dashboard certificate prevents starting the service.
DonP
I can no longer connect to the CBD GUI.  The issue is related to the wildcard certificate that I installed via CBD.
At the CBD VM Console, I sign in and get the status of the cisco-business-dashboard service.
This service keep restarting.  Ubuntu logs show that the service fails to start.  Every couple seconds, it tries to start again.
One error that the service sometimes reports is that it cannot start Nginx.
I check the status of Nginx (web service), and it is not running.
I tried to manually start it with this command:
/usr/lib/ciscobusiness/dashboard/bin/nginx -c /var/lib/ciscobusiness/dashboard/nginx/nginx.conf
This fails with this error:
SSL_CTX_use_certificate(“/var/lib/ciscobusiness/dashboard/certs/cert.pem”) failed
SSL_CTX_use_certificate:ee key too small
I recently uploaded the wildcard certificate we use companywide to the CBD via the GUI and the GUI accepted it without a problem. However, upon restarting the VM, it now looks like the underlying web service is rejecting the cert.
The GUI should have rejected the cert or it should configure Nginx to allow the cert.
Interestingly, CBD worked fine for 2 weeks until I restarted the VM.  Now Nginx no longer starts and I am stuck.
The only solution on the support community for a similar problem says to ‘contact the support centre’.
I tried that but was declined support because of not having a contract number (free version).
Any help you can provide to get the Business Dashboard working again would be appreciated.
Is there a way to set Nginx to allow this cert?
DonP
Using this as a guide, I was able to regain access to CBD:
Ubuntu 20.04 - how to set lower SSL security level? - Ask Ubuntu
Edit openssl.conf file:
sudo nano /etc/ssl/openssl.cnf
Add this line at the top:
openssl_conf = openssl_init
And add these lines at the end:
[openssl_init]
ssl_conf = ssl_sect
[ssl_sect]
system_default = system_default_sect
[system_default_sect]
CipherString = DEFAULT@SECLEVEL=1
DonP
[openssl_init]
ssl_conf = ssl_sect
[ssl_sect]
