Cisco FPR Dual WAN S2S
abreuil
I have an issue when I added a second WAN in my Firepower.
I have a WAN1 with multiple S2S connections, and I added a second WAN. When I change the default route to use the WAN2 by default, I have no longer S2S connection.
Even with adding a route (before default route) for each S2S connection, no tunnel is mounting.
Is there a way to use a WAN only for S2S, and other WAN for every other connections ?
6 Replies 6
abreuil
I saw this link when I did my research, but it seems like this solution is not what I need.
I need that every S2S to use WAN1 only when every other connections are using the other WAN, no failover.
Here are my routes :
for S2S_LAN_1, use outside1 with GW1, metric 50
default route 0.0.0.0/0, use outside2, with GW2, metric100
default route 0.0.0.0/0, use outside1, with GW1, metric 101
Everyone in the LAN has internet access via WAN2, as wanted, but the S2S on WAN1 is not mounting, from any site
but that not work s2s is policy based and follow routing traffic, i.e. the packet must forward through the GW1 then s2s will encrypt the traffic,
here you config gw1 with 101 which make gw2 forward the traffic.
so in your config you must select gw2 and primary and gw1 as backup.
or try config static route for remote LAN toward Gw1 and keep default route as it,
I managed to do this by adding the public IP in my first route :
for S2S_LAN_1 and/or S2S_GW, use outside1 with GW1, metric 50
Thank you all for your time
You are so so so welcome friend
Have a nice day
not entirely sure if this is an option for your specific topology, but you could try ECMP zones as described in the document linked below...
https://www.cisco.com/c/en/us/td/docs/security/secure-firewall/management-center/device-config/710/management-center-device-config-71/routing-ecmp.html
