Cisco Catalyst 3560 POE-8
Curtis777
Hey Guys,
Ive got an old Catalyst 3560 POE Switch.
i was in my cabinet for months.
now i tried to use it again, but i wont boot.
on the left all LED's are lightning up and thats it...
the console stays empty.
7 Replies 7
balaji.bandi
here is console setting should be :
9600
8
none
none
1. Power of the device  ( removing the Power cable).
2.power it back on with the mode button pressed. You will eventually arrive at the switch: prompt.
3.
switch: flash_init
switch: load_helper
switch: dir flash:
You will see anything on the console?
If the console itself not show anything, try a different cable or check this cable on another device working as expected.
BB
of course i tried but this dont help.
also no effect
of course i tried but this dont help.  - Can you explain what did you tried ?
BB
i plugged in the console cable and opened putty
no other cable attached
i holded the mode button on the left while plug in the power.
after a couple of seconds i released the button.
balaji.bandi
Thanks for the confirmation, have you tried the settings i have told, some time putty default has different settings.
1. just to confirm the cable working, do you have any other device to which you can connect this cable and confirm all working?
before we take a bit different steps to fix the issue ?
BB
i confirm this cable works. i tried it on other devices.
its confusing that the switch LED's are steady on on the left side
balaji.bandi
Thanks for the confirmation that cable works as expected.
try quick setup as suggested below link : ( not sure if the console port went bad ?)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/hardware/quick/guide/3560gsg_08.html#wp46780
BB
