Cisco common services integration into ACS 5.0
koeppend
Level 4
Level 4
Hi all
Has anyone here successfully integrated Cisco common services into ACS 5.0?
I have successfully done this with ACS 4.2 but I dont think CS understands the new way to connect to ACS 5.
I have already read the following guide, it basically fails when you click the apply button under AAA mode in CS to connect to the ACS server.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html
So I can see port 49 connects but CS cannot access the web interface to deploy its authorization sets.
-Tacacs+ Connectivity Reachable
-HTTP/HTTPS Connectivity Not Reachable
Protocol mismatch detected.
Ive tried both http and https, get same error
Any suggestions would be helpful.
Cheers all
Dale
Joe Clarke
No, integration with ACS 5.0 is not possible, or will ever be possible. The API hooks to do integration are not available in ACS 5.0. They will be restored in 5.1, at which point support will be added to LMS.
Joe Clarke
Cheers JC
Thanks for the feed back.
Dale
JC,
Any idea when 5.1 will be appearing on the roadmap ?
Dale
The dates I have say middle of November of this year for release, but that won't mean LMS will support it. LMS support will probably not be ready until summer of next year.
