Cisco Configuration Assitent
ricardorojas123
Hi, I connect to UC500 whit the Cisco Configuration Tool version 2.0, ant when I go to Voice Section this messages is showed:
java.lang.NullPointerException
What is the problem?
What's Up?
Lucien Avramov
Level 10
Level 10
A couple of things: there are bugs in 2.0, so please upgrade to the latest: 2.0.1.
The java error comes usually from a wrong configuration on the UC520.
If the upgrade doesnt help, post the java trace output from the java console when you recreate the issue. To start the java console : SHIFT+F2 and then recreate the issue.
