Cisco Configuration Professional HELP!
Dimitris Mingos
Can someone point my mistake to the attached config.
I am unable to use CP. It gives me an error and I am unable to continue configuration.
Thank you
6 Replies 6
srego4
Level 2
Level 2
what is the error?
Dicovered with errors:
Mon Oct 06 22:14:17 EEST 2008 Security feature disabled. (Security feature discovery elapsed time=4046 ms)
Router status
Device Information
Correct the folowing errors:
Error #2032
Any help??
Did anyone used the tool?
Have you tried opening a case with Cisco TAC?
Pl. send log files to cs-ciscocp@cisco.com
& ccp-feedback@cisco.com
alias so that product team will help you resolve the problem. To collect log files, go to the Start menu and select Cisco Configuration Professional > Collect Data for Tech Support, then send the _ccptech.zip file that appears in the folder created on your desktop.
This may be because of the http login failure, can you try creating simple username/password such as cisco123 on router and discover the device using this credential so that we know its not failing discovery because of credential issue.
psreekan
Can you try telnet/http to the router with the credentials that you have configured ?
On examining the router config, looks like the password for user xxxxxxx is specified as 'secret 5' which means encrypted. Try configuring the user with 'secret 0' for password. NOTE 'secret 0' means an un-encrypted password will follow
