Can't get this to work. We have followed the videos from Cisco to the letter. CCP runs, but when we attempt to use Traffic Monitoring, it is as if nothing is getting logged.
In the command prompt windows that are opened after starting the interface collector I see an error that says:
INFO: I/O exception (java.net.ConnectException) caught when processing request:
Connection timed out: connect
Sep 27, 2012 4:02:13 PM org.apache.commons.httpclient.HttpMethodDirector execute
WithRetry
INFO: Retrying request
What does this mean and how do I resolve it?
Using CCP on Windows 7 64bit with IE 9 and Java 1.7.0_03 (I have run the app with runtime parameters
-Xmx256m -Dsun.java2d.d3d=false as well as without parameters if that makes a difference).
Here is exact steps:
Start CCP as local admin
Select device under community info section
Click discover
Wait for discover
Then click MONITOR Button
Select Traffic Monitor and expand
Select Monitor Controller
Install the Data Collector Service (if needed)
Start the interface collector
Command Prompt window opens and error is generated
choose int to monitor
enable netflow on interfaces and start the ccp netflow collector service
Command prompt windows open, no errors, but shows 0 packets collected
i.e. there are lines like this: NetFlow[Thread-11]: Pkts 0/0, 0.0 pkts/sec, 00-00:00:59
