Cisco Connectivity Tests
mystori
I have been trying to complete a marked assignment using Cisco Packet Tracer, but I keep having issues regarding the connectivity test. It always tells me that my connectivity tests for 1 and 4 are incorrect, even though I have done the correct configurations for the router. It appears that this is where the issue appears, though I've asked multiple people and they also do not know why it is wrong. Does anyone have any idea why? Thank you.
@mystori hi this can be due to few reasons.
1. misconfigurations in activity
2. configuration not matching with the activity expected values
3. activity file doing wrong validation  process
check with other if anyone can see the correct values with the same config or consult the lecturer to understand the process.
Good luck
KB
