Cisco Device Monitoring Software
Gregor Blaj
We're deploying a decent amount of Cisco switches and I would like to know if there is any Cisco software (paid or free) which would give me a centralised management platform, monitoring and backups for all the devices?
I know I can use Spiceworks but would prefer something more network device specific which would also log bandwidth usage etc.
Any advice appreaciated.
Cheers.
AFROJ AHMAD
Hi Gregor,
As per your requirement  you can go for Cisco works LMS 4.x
here is the download link ( with EVAL license ,this will work for 90 days ) :
http://software.cisco.com/download/type.html?mdfid=284259296&softwareid=280775102
Here are a couple of others:
http://www.whatsupgold.com
and
http://www.nagios.org/
chekc the  link below  which  have some comparison between several others::
http://network-management.findthebest.com/
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks for that but when I try to download LMS it says I need an additional entitlement?
I'm not a fan of What's up Gold but Nagios looks good.
Cheers,
Gregor
To get the LMS evaluation software, try going via http://www.cisco.com/go/nmsevals LMS will give you the greatest functionality managing wired Cisco devices. Prime Infrastructure 2.0 can also dio similar functions (but not all) and adds wireless capability as well. It's also available from the nmsevals store.
A good open source solution can be put together with RANCID for config backup plus Cacti for bandwidth monitoring.
On the paid product side, I have also seen people have good success with SolarWinds NCM (for configs) plus NPM (for performance).
