04-21-2010 08:48 AM
Quick question - I am trying to get EOT working with EEM but current IOS I have doesn't seem to support the stub-object. I've upgraded my IOS to c2800nm-entservicesk9-mz.124-25c.bin so it should come with Embedded Event Manager 2.2. However when I try to configure a track 3 stub-object, the stub-object feature is not there. What I am trying to do is find a GD release that I could roll out everwhere but I've been through the Cisco Feature Navigator and it would appear that there is none available with the features below ? My estate is a mixture of Cisco 2800 routers....Any suggestions?
Embedded Event Manager (EEM) 2.2
FHRP - EOT integration with EEM
Mary
Solved! Go to Solution.
04-21-2010 10:48 PM
No, all versions of 12.4 mainline have EEM 2.1. To get EEM 2.2, you need to go with 12.4(2)T or higher. I have a 2821 running 12.5(1)M in my lab which has EEM 3.1 and EOT. But you can get it with recent 12.4T as well (e.g. 12.4(24)T).
04-21-2010 10:48 PM
