Cisco EEM Multiple Events
csco10675262
I would like to check if it may be possible to have the following scenarios for EEM:
a. Port A is down and port B is up  --> Shutdown port C
B. Port B is down and port A is up --> Shutdown port D
C. Port A is down and Port B is down --> port C and Port D interfaces is to be UP
Appreciate for any suggestions :)
Thanks.
Seb Rupik
Hi there,
Yes it is possible.
you will need to regex sh ip int br | inc <interface_XX> for the occurrence of for example  "up\s*up" for an interface which is UP. You are not interested in the match that the regex returns, instead the result, ie a 1 means it matches. You can then use this in an if statement.
I'm not in a position to test this, but something like :
 action 01 clie command "enable"
 action 03 cli command "sh int br | inc gi0/1"
 action 04 regexp "up\s*up" "$_cli_result""
 action 06 if $_regexp_result eq "1"
 action 07  syslog msg "Gi0/1 is up!!"
 action 08  cli command "conf t"
 action 09  cli command "int gi0/10"
 action 10  cli command "shut"
 action 11  cli command "exit"
cheers,
Seb.
Seb Rupik
Hi there,
Yes it is possible.
cheers,
Seb.
Thank you for the information! :)
