Cisco firepower 1150 multi internet/ISP connection
msaeed
dose cisco firepower support multi internet/ISP connection? and do it aggregates all the connections or work as load balancing?
2 Accepted Solutions
On this excellent document, Cisco talk about Primary and Secondary interface.(Slide 36) But on the Layer 3  field, you can have only one IP address. I assume that this Firewall does not support multi ISP neither aggregated nor loadbalancing. What you can do is switch over between ISP using some IPSLA or Policy. But not 2 ISP at the same time.
https://www.ciscolive.com/c/dam/r/ciscolive/latam/docs/2019/pdf/BRKSEC-2020.pdf
balaji.bandi
i do not believe you can aggregate the bandwidth with different ISP, instead you can fail over and use Active/Active based mechanism with PBR
good example to start with :
https://integratingit.wordpress.com/2021/05/06/ftd-dual-isp-using-fdm/
https://community.cisco.com/t5/network-security/ftd-1010-with-dual-isp/td-p/4108587
BB
balaji.bandi
BB
