Cisco FirePower
MohKha78931
I am trying to do a Network layer 3 malware detection and prevention test. I tried to download a basic test file from Eicar[.]com. That on its own should have triggered an alert from FirePower. I then looked at the FirePower console under Anaysis>Files>File Summary and I did not see any events. Is there someway to configure FirePower to pick up and Eicar test file as malicious? Are there any other test files I can use that will trigger an alert? Please Advise.
Mark Elsen
 - Make sure to have the needed licensing level for malware detection, further more have a look at this document for guidelines :
         https://www.cisco.com/c/en/us/td/docs/security/firepower/60/configuration/guide/fpmc-config-guide-v60/Reference_a_wrapper_Chapter_topic_here.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
