CISCO FPR 2110
Dear Cisco.
Greetings...!
We have a CISCO FPR 2110 firewall.
Does it supports 'Dual internal LAN' configuration without a router.
Example:  ASA 5505 need a router between every different networks.
Can you please let us know asap.
Sai Kumar
pieterh
I do not understand the question
the statement "ASA 5505 need a router between every different networks." is NOT true !
also with an 5505 you are able to allow between two internal networks without using an external router
- you give both network the same security level
- you need 1:1 NAT between both networks
- you need access rules between both networks
or enable "allow access between networks with same security level"
basically same for the FPR
