Cisco IP SLA problem
islam.kamal
Level 10
Level 10
i have two routers and i need to see LSA , i put the configuration on the two routers which enable SLA . I create opeation and create collection I did not see the traffice or graphs using SLA , please advise i need a help for IP SLA
islam.kamal
Level 10
Level 10
Any update or any answer
Hello Islam,
Can you describe your problem little bit further?
What exactly it your topology and what do you need help with?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
