ODBC access to LMS DB doesn't work
Michael Whiteley
I have an application that returns 'provider not found' when trying to connect to the 'CiscoWorks embedded database'.
The dbodbc10.dll files were copied over from the LMS server and registry entries made per the manual.
The system Dsn was set up and tested fine in Data Sources (ODBC)
Is there a utility somewhere in the LMS distribution that registers the provider so it can be found by apps?
Thank you
Mike Whiteley
ngoldwat
Level 4
Level 4
Depending on OS and LMS versions you may be running into CSCto44917.
