Cisco ISR 4331 not working as DNS properly
EduardR
Hi all,
I got an issue with a Cisco ISR 4331, it has been configured to work as a DNS for some small network with other network devices (Nexus, Catalyst and others), but the name resolution is not working properly. When I use the resolution form the Nexus devices, it work fine, but from the catalyst it does not work.
My DNS configuration in the 4331 is this:
ip host TEST1 10.10.10.1
ip host TEST2 10.10.10.2
ip host TEST ns NS1.TEST
ip host TEST ns ns.TEST
ip host ns.TEST 1.1.1.1 <- Router IP
ip domain name TEST
ip dns server
ip dns primary TEST soa ns.TEST admin@TEST 86400 3600 1209600 86400
The Nexus has this line:
ip domain-name TEST
ip name-server 1.1.1.1
And the Catalyst this one:
ip domain-name TEST
From the Nexus I got:
NEXUS# ping TEST1
PING APIC-1 (10.10.10.1): 56 data bytes
64 bytes from 172.28.36.1: icmp_seq=0 ttl=63 time=1.49 ms
64 bytes from 172.28.36.1: icmp_seq=1 ttl=63 time=0.569 ms
But from the catalyst the output is:
CATALYST#ping TEST1
Translating "TEST1"...domain server (1.1.1.1)
% Unrecognized host or address, or protocol not running.
Is there something i am doing wrong with this configuration? Does anyone has an ISR working ok as DNS? Any help will be appreciated.
resolveits
Did you ever find a solution to this problem as I also have the same issue. Thanks.
you are running into this on a Catalyst switch, a Nexus, or an ISR router ?
Hi Georg,
Thank you for your quick reply.
I discovered that my NAT was not configured properly in that I had "ip nat outside" configured on the wrong interface. After adding "ip nat outside" to interface GigabitEhternet0/0/0 in the config it started working. I do not understand why this is the case because I thought the correct outside interface is the Dialer1. Please see config below.
In addition, I now have the problem whereby when I ping a domain that is pointing to my public IP address, the ping returns the internal IP address of the router on the inside interface (being 10.0.0.1) instead of the external IP. When pinging sip.aus.co it should be returning ipv4: 203.194.xx.xxx.
I use the domain sip.aus.co for my ITSP to locate my equipment.
eg:
[From Router]
ISR4331#ping sip.aus.co
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
[From PC returns IP address of PC]
C:\Users\CO>ping sip.aus.co
Pinging sip.aus.co [10.0.0.110] with 32 bytes of data:
Reply from 10.0.0.110: bytes=32 time<1ms TTL=128
Ping statistics for 10.0.0.110:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
=============CONFIG============
ip name-server 8.8.8.8
ip domain lookup source-interface GigabitEthernet0/0/1
ip domain name isr4331.local
ip dhcp excluded-address 10.0.0.1 10.0.0.99
ip dhcp pool data
import all
network 10.0.0.0 255.255.255.0
dns-server 8.8.8.8 1.1.1.1
default-router 10.0.0.1
option 150 ip 10.0.0.1
domain-name isr4331.local
interface GigabitEthernet0/0/0
description Arris CM8200 NBN
no ip address
ip nat outside    ! <---  I added this here
media-type rj45
negotiation auto
no mop enabled
interface GigabitEthernet0/0/0.2
description WAN Connection VLAN 2 TPG
encapsulation dot1Q 2
pppoe enable group global
pppoe-client dial-pool-number 1
ip address 10.0.0.1 255.255.255.0
ip nat inside
negotiation auto
no mop enabled
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp pap sent-username xxxxxxxx password 0 xxxxxxxx
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http client username cisco
ip http client password 0 cisco
ip http path flash:
ip tftp source-interface GigabitEthernet0/0/1
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip ssh version 2
access-list 1 permit any
odd indeed, as the dialer interface is the outside, so 'ip nat outside' applied to that interface should be enough, in theory.
In any case, change the access list 1 from:
to
access-list 1 permit 10.0.0.0 0.0.0.255
