Cisco LMS netconfig job not saving running config to startup
CB90021204
I'm running LMS3.2 and RME 4.3.1. I deployed a netconfig job to our network which consisted of approximately 800 devices.
The report said that the job completed successfully however some of the devices didn't save thier running config to startup. Has anyone experienced this before?
Is it possible to add a command or issue another netconfig job just to save the running config, so I can identify if the job fails on some devices? Using the tick box in the netconfig job doesn't seem to alert you if its not successful.
Sven Hruza
Level 4
Level 4
normally you have at the end of the netconfig job dialog a option to save the config.
If this didn't work on some devices you will get an information in the Job log.
On which device Type it didn't work?
Sven
Duong Nguyen
I have seen in the past where someone is running a netconfig job with the cmd to "wr mem" as a line in the netconfig job.
Sven is correct, there is an option; radio button/check box to save the running config to startup after the job is completed.
if your job is strictly meant to "wr mem/write the config" then run a show command in config mode (non-enable) mode and select the option to save running config after job is completed.
